Mike-sps
- Oct 20, 2020
- 4
Good day to you all, I am challenging myself to build the smallest 200Ah power wall with a twist . There are so many videos on how to build a power wall but I don't seem to trust there content. I know that you guys will be able to give me the advice I need.
I want to fit all the components in to a box, size in inches. H20 x L32 x 3.5
Quite a challenge!! and existing.
The lifepo4 batteries will lay flat in series to accommodate the 3.5inc
I am not sure if I need to make use of pc boards for the inverter, charger. The Daly Bms should fit, is active equalize balancer necessary. Thanks for the support. ??
