d2dai00566
- Jun 9, 2022
- 16
Hey guys I'm new to this forum. Thank you for the add. I have posted questions about my system and people in facebook groups always tell me I need to speak to engineers because of my system size which is why I put it in this section. Finding an engineer to consult seems easier said than done. No engineer I've called wants to work with a DIY'er without charging over $5000-$15000 for consult and plans. So I'll explain my system and my current hiccup. I am building a 21kw array. 550w trina bifacial panels. I'll be using 4x MPP LV6548 inverters. I'm going to either buy a bank that has 90KWh storage or build one. I'm still deciding. This is going to be an off grid system. My house is large and I have a few workshops and ac's I need to power here in south florida. My house is fully grid tied right now but I am going to change that and go fully off grid. I've searched high and low and everything I see just doesn't solve my issue. I understand all the typical house wiring. I understand all the pv wiring and disconnects. I understand how to wire up the batteries with bus bar's and a bms. What I'm struggling with is connecting this to my house. I currently have a 200 amp main panel. I'm in USA so its split phase 120/240v. I have a sub panel in my house that is 150 amp in the addition that was built. Then I have 2x 70 amp sub panels in the shops. Obviously I just need to power the main panel to supply the rest of the house? However, my main issue is how the heck to I connect to the main 200amp panel? I see everyone connect by back feeding subpanels with double pole breakers. But everyone does this with smaller amperage breakers. And I don't think using 4x 50 amp breakers to feed the panel would be safe (one breaker for each inverter). I know that my main service is 2/0 wire in the main lugs. However, the inverters only support a smaller gauge wire for AC output. What am I missing? The only possible thing I could think of would be using a copper bus bar and connect all the smaller gauge wire from the inverter AC outputs into that bus bar and bring 2/0 wire from that bus bar to the main breakers in the panel. This is a complete guess. My knowledge of solving problems is extremely limited. I'm just basically skilled at the necessary labor and can follow plans. If anyone could help that would be great or point me to an engineer that is willing to consult for free or a reasonable price then I'm totally willing to speak with a professional as well.
