So I replaced four of the BMS circuit boards in the liFePo4 Powersonic Batteries with Daley 4S 12V 30 Amp BMS modules, two dumb hardware BMS, and two Smart BMS modules. The Daley Smart BMS modules are twice as expensive, but they allow you to set various parameters, includes a temperature sensor, and you can hook up a small display that shows the approximate state of charge & has a reset button. You can also hook up a Bluetooth dongle to read/set various parameters on your phone app, or a custom touch screen.
So, after installing four BMS boards, I started looking at the original BMS board on the next battery. The flaw seemed to be in the bank of MOSFETs right before the output. I started measuring the voltage on each of these MOSFETs, and lo and behold the BMS started working! I did this with eight more batteries, so it doesn’t seem to be a fluke. The disadvantage of the OEM BMS, is that you can’t read/set various parameters.
I bought these for 25$ each for a 50Ah battery, (I actually could have got them cheaper) so this seems like a pretty good deal compared to $700 for a 100Ah Battleborn battery!
The next question is what’s the best way to wire them up. The problem with a 12V system is that you need a scary amount of Amps to get a decent amount of 120V Amps. #2 AWG wire is good for about 120 Amps. That will only give you about 12 Amps 120V after going through an inverter.
I originally used #8 wire going from each of four batteries to my inverter. #8 wire is good for about 40 Amps and the max of my Valence batteries is 30 Amps, so that’s good. I also got a bunch of #4 wire from my friend, and I bought some #2 THHN to run to the relay in my electrical cupboard above the drivers seat to my Renogy 60 Amp DC-DC charger. The relay is connected to another #2 cable that runs to the bus’s two high capacity alternators. #4 wire is good for about 100 Amps, so that’s nice. #2 in the chart I used is not too much better.
https://www.bluesea.com/resources/1437
So a dozen batteries means about 48 connector terminals. I’m lucky, I have a big old 2 ft long Nicopress crimper that will crimp the hell out of any terminals. Should I solder them in addition? Seems unnecessary…. I have to arrange my batteries in a grid under a bench seat right behind the drivers seat In a 4x3 grid or a 2x6 grid. The batteries are 7.7” x 5.2”. I could wire them all in parallel with #4 wire, but that’s a little skimpy. Or I could wire each row with #4, and wire the rows together to the inverter with #2. Still not heavy enough to get me more then 10-12 Amps 120VAC. Or am I figuring this wrong? How long should I make the cables? A standard 12 Inch or 6 Inch? Or custom just long enough? I know that the total path to each battery needs to be the same with the same wire.
The other option is to use sizable rigid bus bars. That’s cheaper, but it’s … well …not very flexible, you have to arrange the battery terminals just so in a line. You have to drill holes for each connection. My batteries have recessed terminals, so I would need to find some stand-off bushings. But then you don’t need to worry so much about wire size or length.
