Micah123456
- Jun 29, 2022
- 50
Can't find another thread. I have a PowMr 3500watt unit, 120volts, all in one. Works perfectly outside of the MPPT charge controller. After a day or so, it doesn't reset the voltage, goes down to 50 volts in and when sun is up, it doesn't reset to its 113 or 120 volts coming from solar panels. Ie its not tracking voltage regularly and adjusting backup to get full power. So i get half the wattage out of my panels as its not rechecking the voltage.
Has anyone seen that? Any fix? The only way to fix it I see is to disconnect solar and reconnect which forces it to recheck the voltage. Can't find others really talking about any solutions for this one.
Does the growatt do the same? If i purchase another, wondering if I'll have the same issues.
Running 1200 watts of panels, close to the 150 volt max. What i see normally is about 140 volts in. 145 volt VOC max according to unit but manual says 150 volts.
