I am considering wiring in a pre-charge circuit for my solar controllers using a 100 watt 30 Ohm resister a switch and probably 10 guage wire to essentially bypass the main breakers to the SCCs and a separate bypass with another resistor for the inverter. The goal is to pre-charge capacitors prior to connecting the main current to these devices to reduce arcing. Is this a good Idea, a bad Idea or just over kill. In theory given electricity takes the path of least resistance in practice I probably would not need to turn off this circuit when I switch the main power on, but will always switch it off in practice
