Hi,
I’m finalizing preparation for the GB/FB/outdoor batteries.
The EG4 battery manual calls for ensuring all batteries are the same voltage prior to connecting them all together.
In my case, all 12 of those batteries will be connected to a bus bar.
Batteries will be here in a couple weeks, I am not sure what voltage they will arrive at. 50%? I have one chargeverter, I plan on charging each battery to full prior to connecting them all together.
Is that the way to go? Or should I aim for all of then being within an arbitrary target? The closer the better but what’s good range to aim for?
Lastly, once they’re all within this range, and I connect them all together by turning on the disconnects on the bus bar, how long should I wait for the individual battery voltages to even out before turning on the inverters?
Alternatively to the chargeverter, would it be better (or worse) to use one of the FB’s to charge the batteries? I have a string of 8 panels that I could use for that. Note that initially I won’t have any string PV, they will come in a couple months ago. So when the GB/FB gets commissioned I will only have 45 panels with microinverter on GB’s smartport.
