Inverter 48v battery input capacitors range from about 20,000 uF for low-cost HF 5kVA inverter to about 30,000 uF for LF inverters.
Total initial series resistance for BMS, batteries, cables, breaker, and capacitors ESR ranges from about 15 milliohms to 30 milliohms depending on particular system setup.
16S 48v Lithium battery with system of 15 milliohms total series resistance and 25,000 uF inverter input caps will have an initial peak current of a little over 3500 amps that decays off exponentially to low current level in about 1 millisecond.
You really don't want to subject any DC circuit breaker contacts to that initial surge current. Some BMS's will trip overcurrent protection and you really don't want to expose the BMS MOSFET's internal wire bonds to that much current surge. If you have a fuse instead of breaker system it may blow out fuse.
2 ohms resistor across breaker cable terminal lugs for at least 0.1-0.2 second before you flip the breaker ON will pre-charge inverter caps so you only subject breaker contacts to a couple amps max.
Nothing fancy really needed. I may be a bit unusual, but my inverters have had continuous applied battery power for over 17 years straight. That was the last time I actually used a pre-charge on inverters.
