Metalophile
Analytical Chemist
Hi all, I'm fairly new around here, but I have had a small off-grid 12v lead acid battery system fed with 150 watts of panels and an MPPT charge controller for off-grid backup power for years. Mainly it is there to run my ham radios and for some power to have in case of emergencies and grid failure. I live in a suburban area, and I want to be prepared in case of a grid-down situation - either from solar flare, grid hacking, or EMP scenario. One of the gaps in our prep plan is food storage. We have a lot of frozen grass-fed beef (expensive) in chest freezers in the garage near the front of the house. But my best panel area is a sunny spot in the back yard, about 80 ft. from the garage. Wife is dead set against moving the freezers to the back patio closer to the solar panels. I have plans of expanding my ground mounted panels in the back to about 600 watts, but then I move and expand my batteries from the patio at the back to about 3kWhr of LiFePO4 into the garage so the battery pack(s), MPPT, and inverter would be there close to the freezer(s). I live in the mid-South of the country, so it definitely gets below freezing at times in the winter. I had planned to keep the LiFePO4 in the garage where it doesn't drop below freezing. However, that's a long run of wire from panels to the MPPT - 80ft. Now, I'm having concerns about running 10AWG solar wires from the back yard, through the attic to my garage. I calculate that long of a run with a panel voltage of ~28V will cost me a few percent of power. If a code enforcement officer sees that he might object to that - and if I have 600w of panels it will pretty much be visible from an adjacent street. Also, having my solar system in the garage which is attached to the house - does that raise any safety concerns? So before I drop a couple of kilobucks on this project, I wanted to bounce this project idea off of this forum - especially the safety aspects. Am I overlooking some easier way of powering one or two chest freezers off grid? Maybe build a shed for my solar system and the freezers in my sunny spot?? Also, I have thought about getting a conventional grid-tie system with 5-7 KW of panels on the roof. Not sure I would want to do both systems simultaneously, but the grid-tie system doesn't do anything to solve our solar powered freezer storage goal - unless I have the installers add a couple of extra panels for my off grid subsystem - does anyone do that - and would code enforcement object to that?
