workaholic
Received an order of 16 cells for a battery build. Each terminal has a green protector with a sticky substance attaching it to each terminal. Is there a recommended glue remover I should use to remove the substance that won't damage the terminal face? I don't want to use too harsh of a solvent that could possibly etch the surface of the terminal.
Also, I am planning on using a thin layer of nolox between the terminal and each busbar (tinned copper). Should I also use a thin layer between the bus bar and the bms lead, or just install it dry on top of the bus bar then torque everything down?
