Rednecktek
Solar Wizard
So I've got a sailor buddy who pinged me about doing solar on his barn out at his place in Eastern WA and gave me a bit of a head scratcher.
He's got a barn style shed out there that he wants to split into 3rds for an apartment/garage/shop and run the whole thing on solar since it's a couple miles to the nearest power and at $4/ft that adds up right quick!
The "Plan" he's doodling out is to use a pair of the EG4 6.4Kw AIO's in parallel since he needs 240v split phase for the well, the welders, the plasma cutter, and a real size AirCon mini-split. The plasma cutter and welders both want 50a outlets so he figures just get the 6.5k's which should leave him plenty of capacity. A stack of the Trophy heated batteries (because it's COLD out there when he's at sea!) and a rack and good to go. He was smart enough to never get married so he can actually afford all this.
Here's the conundrum though, the panels. Like I said, it's a barn style roof and the building faces N/S so he's got the idea to put an 8s string of Trina 240w panels on each of the slanted sides AND right down the center of the roof. My confusion is this:
An 8s3p setup with those panels gives him about 320v and 8a per string (rough numbers) but each AIO is only going to have the inputs for 1 string, so where do you stick the 3rd string?
Would you do:
1: 8s2p into EG4-1, 8s1p into EG4-2?
2: 8s1p into EG4-1, 8s1p into EG4-2, 4s2p into an EPEver 200v model?
3: Some magical MPPT that can take 400v PV input and put the 3rd string in parallel?
4: Some other magical option?
Ideas on which way would be best and why?
Thanks y'all!
Would you do:
Thanks y'all!
