Cheap labor probably get paid by number of cells per hour. And inexperienced driller decides what is good enough.The issue is they send these out to whatever "machine shop" has capacity and good price. That sometimes means the guy in the back alley with the hand drill....
I'm going to send the reseller some more detailed pictures today so I can discuss my concerns with them tonight. In their current state, I consider these cells unusable for my application and therefore would expect some sort of refund or credit. Not sure what a reasonable outcome looks like, but these would take at least a couple hours of work by a skilled machinist to repair (or a whole day if I do it), with the cost of labor and materials (flat bottom drill bit, bottoming tap, or helicoils) I'm afraid I'm stuck throwing good money after bad to make them work.
Custom bending grub screws sounds viable, but it also sounds like a fiddly process and will still result in asymmetric loading on the threaded aluminum. With the off-axis tapped hole, there's no way to get a proper perpendicular clamp on the threads which are the weak link in this joint. I agree that having the bus bars flat will ensure a proper path for the electrons, but the mechanical joint is what concerns me the most. Can you tell I'm a mechanical engineer and not an electrical engineer? Once those threads yield and you lose clamp, the quality of the connection will degrade and could leave me stuck with a dead battery in the middle of nowhere.
-uberpixel
So, you installed M8 helicoils? I could see the benefit since they would be a bit more standardized with other terminals in the system and typical lug sizes. I was debating whether it's beneficial to increase the bolt size since the bolt really isn't the weak link, it's the aluminum, and an M6 stainless bolt can supply far more clamp load than the threaded aluminum could ever support. Plus with a lower thread pitch, you're getting fewer threads of engagement for a given depth. That said, with how off-axis my holes are, drilling for an M8 helicoil tap will ensure that I have a clean hole to tap with no remnants of the previously drilled/tapped hole.I took option #1 and helicoiled all mine right after doing a inspection and random capacity test to make sure the cells were ok.
Even though the quality of the threads were very good (I went with a more expensive reseller who 'balanced' the cells I received) I wanted M8 studs to properly fit my batteymon M8's from Batrium and the ability to get some reasonable torque on the hardware. I do a lot of marine work and know that torque and corrosion seal are key for many years of trouble free operation of stud-type connections.
Understood. The M6 or 1/4" lugs are certainly available, but I was thinking it could be nice to use M8 or 5/16" lugs to match things like power distribution blocks, battery cutoff switches, bulkhead connectors, circuit breakers, etc. Just less differentiation in lug sizes to order or keep on hand.An M6 bolt is very close to 1/4". There are plenty of 1/4" lugs available. I used 1/4" lugs and they fit just fine without any modifications on my M6 screws.
Ring Terminals (Tinned Copper)
temcoindustrial.com
Curious what kind of cells you had and how deep you drilled the holes? Did you have to trim the helicoils to fit. Also, how did you break the tang at the bottom of the hole?
-uberpixel
Yeah. No thanks on the first option. Loading up one half of notoriously weak threads sounds like a recipe for disaster. Maybe some self aligning spherical washers could help, but the limit on those is only 3-4 degrees of correction. These studs are more than double that amount of misalignment.I would put a couple washers under the head and torque the nut to the recommended amount for aluminum threads. The stud may straighten on its own.
If it doesn't, get a piece of steel tubing with a 6mm hole in the end. Another option is a 6mm threaded rod coupler (leave 1 thread exposed at the bottom). Then gently bend the stud square. I suggest using loctite on the stud once straightened to keep it from spinning out of plane later.
Following on Steve's comment that the busbar and contact pad is the surface of concern I also want to refer back to your proposed usage and reliance upon the bolts and nuts as a mechanical connection. These terminals should not be relied upon as the (sole or primary) mechanical connection between these cells. The terminals will fail regardless of their original state. There are discussions on this board about how to compress the cells and use vibration reduction. This will need to be done if you are going to put them on the tongue of a trailer.Two items that pop out.
1) The bolt/nut are not the contact surface you have to worry about. It is a matter of having the BusBars make smooth full contact with the contact pad on the cell which is where the electricity is supposed to pass through. THAT is the essential part, is that contact between busbar & pad.
2) The BMS Lead with Ring Terminal has to make Good Solid contact on the TOP of the busbar and also be secure. The slight bit of angle shown there is "not that bad". You can use a flat-washer then the Ring Terminal then serrated locking washer & nut on that. Do NOT tighten more than 30PSI.
BTW: A Tip that can be useful in this type of instance.
If you use a flat washer over the the busbar & BMS Ring terminal, there are "Lead" washers which can make up for the slight angle as they are soft and will "squish". These can only be used ONCE ! If you ever loosen them to make a change, you will more than likely have to use a new one to replace it. Lead Washers are hard to come by now because of the "lead" the alternatives out there exist but are quite costly.
NOTE: There are many grades of Aluminium, what is used on Battery Cells is very soft. This in NO WAY compares to Aluminium used for making Motors or Automotive engine components. I've rebuilt more car engines than I count. My Last engine build was a Chevy 402 BBC that Dynoed up to 10,000 RPM and made monster power complete with Roller Valve train and all the best goodies which was far from cheap.
Cinergy also just posted this resource (a Video), which may answer some questions and provide an option to those who are willing to give it a shot...
Repairing an aluminum terminal on a LiFePO4 cell
I made a video documenting my process:diysolarforum.com
Good point, and thanks for the reminder/clarification. I don't intend to rely on the mechanical connection of the terminals to hold the cells together. I will use some method of strapping or compression (still debating my approach), but even with strapping or compression there could still be some mechanical force input into the terminals due to small expansion or contraction of the cells and also general vibration of the entire assembled pack.Following on Steve's comment that the busbar and contact pad is the surface of concern I also want to refer back to your proposed usage and reliance upon the bolts and nuts as a mechanical connection. These terminals should not be relied upon as the (sole or primary) mechanical connection between these cells. The terminals will fail regardless of their original state. There are discussions on this board about how to compress the cells and use vibration reduction. This will need to be done if you are going to put them on the tongue of a trailer.
Hopefully you used a credit card and can do a charge back. If the vendor expects me to fix his screw ups, they would quickly find out how much I make an hour. This is not acceptable.Do you think I am justified to ask for some sort of remedy from the reseller? These were purchased from what I believed was a reputable reseller (possibly one of the most frequently mentioned on this forum) but they are so far not offering any solution to resolve the issue.
I can't imagine that these will be okay over their lifetime if nothing is done to straighten the holes.
I'm thinking best case they send me replacement cells or refund my purchase price - worst case they refund enough of the purchase price to pay a machine shop to fix the messed up terminals - although I'm not sure how much a shop would charge to do the work - might be as much as the cells are worth. Fortunately I only ordered 4 cells so far, so 8 terminals to fix - could be worse...
-uberpixel
