I recently bought two 100Ah SOK batteries. I charged each with a NOCO g26,000. When the NOCO said they were charged, voltage was 13.3, which I understand To be somewhere in the 80-90% range of SOC.
I installed them in my van, which charges from the NOCO, a 40A Renogy B2B, and a Trimetric Solar Charger with 300W panels. Very quickly, voltage shot to 14.6 and the meter read 100%. Overnight, I applied a load I knew would consume 50A overnight, and, sure enough, this morning the meter read 75%.
Then I set about to charge them, and that's when the trouble began. Voltage of the batteries with 0.4A parasitic draw is 13.4-5. Solar would show 0 amps coming to the batteries with maybe 10A unused—the van is in the shade. The Renogy would act as if everything is hunky-dory, yet not send a single amp to the batteries. Green light on, red light off. IOW, everything acts as if the batteries are charged, yet I know they aren’t because I took 50Ah out and haven’t replaced them.
Renogy is set with S1,2,3,4 DOWN and S5 UP to charge lithium at 14.6V.
Temperature Sensor was removed from the Trimetric Solar Charger. Relevant Trimetric settings are as follows:
P1 (Absorb Volts): 13.8
P2 (Charged Set Amps): 2% of Capacity
P3 (Battery Capacity): 200
P8 (Max Allowed Voltage): 14.6
P10 (Assumed efficiency factor) 99
P12 (Auto Reset SOC): OFF
P14 (Max Absorb Time): 0.5 hr
P15 (Max volts finish charge): 13.1
P16 (Float Voltage): 13.1
P20 (Overcharge %): OFF
P21 (Finish Stage Current Limit) OFF
We were supposed to leave on an extended trip tomorrow. I guess that won’t happen, but any assistance would be greatly appreciated.
