Off grid setup not detecting any PV input... any help suggestions would be greatly welcomed, I am but a noob,...
I have finally finished assembling my 48v Lifepo4 16s battery and hooked it up to inverter.
Heres my setup:
Inverter : I have the following inverter off grid 5kw https://voltaconsolar.com/off-grid/conversol-v7-off-grid-inverter.html (rebranded Voltronic Axpert King/ MPP Solar....)
Panels: 10 x 345w JA Solar Mono MBB Percium Half-Cell 9.86A 41.76VOC ( in series)
BMS : Selpos 48V 200Amp
cells 16 x 280AH Lifepo4 48v
BMS seems to start OK - shows 50% SOC green status lights = good. (I havent changed any settings at all from stock.)
Connected to the inverter , used pre charge resister and set battery isolator to on.
Inverter boots up and runs. (again I have not changed stock settings)
Can see battery voltage - so far so good!.
I did notice that SOC went down to 6% suddenly!? after 5 mins or so is this normal.
However - PV input remains at 0, tried tripping PV isolator doesnt seem to do anything.
Panels are in 1 string of 10 series voc 417.6 9.86A (Inverter should be able to handle 500Vdc )
I tried my multimeter on the fuse isolator outside - I think I can only get 370V? - if I divide this by 41.76 I get 8.86 panels, does this mean 1 panel is not working? (or is it just the bird poos /dirty panel) *Im in UK and suprisingally its the hottest day of the year today - extremely sunny!
I did 'hear' a spark once when I tripped the outside fuse box for the PV string....
If I isolate the panels I can see 51V on the Inverter PV terminals - is this something to do with battery configuration? (its all off grid) is this battery feedback , feeding back to the panels?
Any pointers on checks I need to do, the inverter doesnt have any fault code displayed...
48 v Battery > BMS > Class T Fuse > Isolator switch / Pre charge resister > Inverter
Panels > Fuse box outside > DC Isolator inside > Inverter
Heres my setup:
