Corbury
- Jan 23, 2021
- 56
Hi - So last spring I built 2 x 12V batteries each with 4s 280Ah lifepo cells and 120A overkill solar BMS. I top balanced the cells and hooked everything up and it seemed to work great. Then I installed the pack in my van and discharged to around 50% - since it was going to be a few months until I finished the van. The overall system is victron multi-plus 3000 and victron solar charge controller (not configured yet). The guys at inverters R us configured the multi-plus for shore power charging with generic life4po batteries (this might be the issue). BTW - i torqued everything to spec (but maybe something is loose)?
Issue
I recently charged up the batteries with shore power and I saw a lot of cell over-current alarms on one of the batteries. The first charge showed the capacity at 271Ah - now they are showing at 243Ah and 100%. What happened here? I've posted some screenshots.
Thanks for any thoughts here,
Clyde
Issue
Clyde
