400bird
Solar Wizard
I think you need to look at your BMS and settings, it should never have allowed that cell to reach 3.97 volts.2. take them mostly apart (by removing the BMS)
Interesting. I was hoping that these battery modules would be pretty much like an SOK or similar - no need to disassemble when storing.For many installs, when the batteries won't be used for months at a time, everything gets disconnected from the battery. That would include both the BMS and any active balancer.
I posted the settings at the start of this thread - cell overvoltage trigger setting is 3650mV and cell full voltage is 3400mV. I think these are the right settings?I think you need to look at your BMS and settings, it should never have allowed that cell to reach 3.97 volts.
it this what I'm looking for? I'm just concerned this is too small?
Have one on each of my batteries. Never did a top balance. Works good.it this what I'm looking for? I'm just concerned this is too small?
Yes, I put them in parallel, charged to 3.65 (max according to spec sheet) to make the 3 lower voltage cells go to the highest cell. Then get they at 3,65 for 2 hours. As I wanted to see if the highest cell was broken, I then disconnected the parallels and measure every 3 hours the voltage without loads. The highest one is not moving from 3,62v (36 hours resting) when the others are at 3,49v.You put the cells in parallel and top balanced to 3.65v and then seperated the cells and 1 cell is still higher than the rest?
I want to wait some days to see if they stop in a rest voltage and then will do the deep discharge test. Just did once and according to what I wrote delta was 50mv.I don't think there is much that can be done except to replace cells. What happens at the low end when deeply discharged?
Consider an active balancer as these cells may need more balancing than the BMS can provide.
Ok, so charging just to 3,45 and see if they 4 charge equal?At that state of charge is only takes a few amp hours.
try using a resistor to lower the high cell to the same as others or if one is low use
a lap power supply to bring it up the others
When above 3.4 volts very small changes in charges make a large difference in voltage.
At 3.5 volts it is even smaller.
I get mine to be close at 3.45 and leave it be. The amount of amp hours difference is in the low single digits when about 3.45
If the high cell is also the low cell then it would seem to indicate diminished capacity and subject to replacement.I want to wait some days to see if they stop in a rest voltage and then will do the deep discharge test. Just did once and according to what I wrote delta was 50mv.
Would you change the highest cell or the 3 lowers?
Thanks!
Those settings look fine, but if your BMS was working it should have disconnected long before your cell reached 3.97 volts.I posted the settings at the start of this thread - cell overvoltage trigger setting is 3650mV and cell full voltage is 3400mV. I think these are the right settings?
I know - that's what's worrying me. As well - now the BMS is showing 100% at 243Ah - instead of the 271Ah it used to show. This was part of my concern about toasting the batteries. Why did the BMS show this "new" and diminished max capacity - when I did not change any BMS settings?Those settings look fine, but if your BMS was working it should have disconnected long before your cell reached 3.97 volts.
Just finished almost an identical setup, 2 x 280 for redundancy and the JBD units and I left the settings default while my initial test bank (4S) charged up to around around 3.43 volts and then as the SOC was approaching in the high 90% range one of the cells headed for 3.55 and the JBD went into a cycle mode of up/down. Otherwise in my case, it's the microwave (165A) that saddles them with the rest of the time a small load.This is indeed what I have been using.
Good point - to my knowledge - the answer is NO. Max I can see from my screenshots is 3.616. Maybe the 3.97 is from another poster?Corbury, did one of your cells actually reach 3.97 volts? I do not see you mentioning that in the thread.
How many charge cycles since the reset?But coming back to the max capacity for the battery - has anyone seen the BMS (overkill solar) "reset" capacity to a lower number - by itself?
Thank you! Interesting - so I also have a Victron BMV - battery monitor - I was thinking that the BMV indication was less accurate than the BMS - but maybe I'm wrong?How many charge cycles since the reset?
You screenshots showed just a couple; from what i recall 2 and 5 charge cycles. These would be my guess at minimal cycles to start getting good capacity and SoC numbers.
FWIW, while i have Overkill BMSs (2 in continuous use), i do not pay attention to these numbers. I think the BMSs safety features are what they are build/designed for and the capacity/SoC calculations are VERY rough, at best.
