Problem with growatt split phase
I just hooked up my 2 growatt spf3000 lvm48p inverters and have them set up for split phase operation. When I turn on the breaker to the inverters I get the warning number of 16. Which is, Parallel input phase error. Can anyone helpe with it? Thanks.
Hello can you assist me I think I am experiencing the same problem as you were. Could you let me know how you determine which one of the equipment was bad?
For one, the bad one was making a buzzing sound. Also, I disconnected the ouput and checked the voltage phase to phase and phase to ground. The good one was making 120v to neutral but phase to phase I had nothing. Checking the other one it had nothing coming out. I then removed the parallel connecting cables and ran them as 2 separate units, still nothing on the one unit but the good was was still good.
Okay I will try that check today
Thanks
I'm not sure if you two have fixed this issue yet, but if not, try the US service number (818) 800-9177. I had a different issue that the service tech handled quickly. I left a message describing my issue and he called back in an hour.
Thank you. Yes I have. Turns out it's what I thought it was, bad unit. I sent it back and got a replacement and all is good. Thank you for your time in replying to my issue.
