sunshine_eggo
Victron's little biatch
Right, I said it.
Right, @upnorthandpersonal said it was a bad idea so I dropped the idea like 25 posts ago.
Why do you keep bringing it up?
Because you did, and you haven't acknowledged there's a difference between this:
Unless I misunderstood him, mod said that's not a good idea. https://diysolarforum.com/threads/p...9-on-2-separate-batteries.100491/post-1366204
and what I proposed.
They appear to be completely different things.
And why do you keep repeating the word insane and applying it to various peoples' ideas here, each time with zero explanation?
Informal definition is shocking; outrageous, e.g., "Bro was making insane amounts of kWh!"
Maybe start by revisiting the definition of "insane." You're misusing the word.
The idea that you could swap the sense leads for cell #4 and #9 is "insane." You will be measuring the wrong things, and the BMS will shit its pants.
Thinking a 4mV voltage drop/bump under 50A of current is going to interfere significantly with balancing is "insane," ESPECIALLY if an active balancer is involved. The resistance of a charge/discharge circuit does not alter the mAh requirements needed for balance. It changes the Wh which simply alters efficiency, not total mAh needed to maintain balance.
What am I not explaining?
I get that I'm probably coming across as a dick. That is not my intent. I rarely mince words, and I hope you get that I don't take myself too seriously with responses like this:
