lonewolf754
- Feb 12, 2020
- 30
The problem I'm having with this charger is that I can't get it to charge
in Constant Current mode. I first set the voltage to 3.6, then touch the
positive and negative of the charger together to set the amps to 9. When
I hook the positive and negative outputs to the 280AH Eve cells, which I
have paralleled, the charger shows the proper voltage of 3.6, but the amps
are only at 3.8. The cells are now at 3.32v so I believe it should charge in CC mode.
The seller tells me that I need to raise the voltage to 3.8, 3.9, or 4.0 in order
to get the charger in Constant Current mode. The seller says that the charger "thinks" that the battery is almost fully charged so it switches to Constant Voltage mode for the final absorption of the cells.
Anyone that has dealt with this, please inform me if this is what I need to do. These are 280AH Eve cells and I must charge them in the house. I don't want to do anything wrong that could possibly cause a fire or cause one of these cells to vent.
I purchased these cells from Amazon using Will's link from his site and they're supposed to be Grade A cells. They have their posts welded and their numbers have been rubbed out. They are not swollen, and they hold their voltage without any signs of self discharge. The seller of these cells said that they were purchased by a company but were never used. They purchased them from the company, welded the terminals, and rubbed out their identification numbers as requested by the company they purchased them from.
