D
Deleted member 9967
Guest
[Moderator Note]: This thread began here and has been moved to its own dedicated thread:
[Moderator Note 2]: This thread has been locked and has been heavily edited due to an overwhelming number of less than excellent comments made out of anger/frustration/emotion. The flow of conversation may not make sense to future readers as many posts have been deleted or edited by the moderators. Please try to be respectful to one another (especially when in need of help), supportive, compassionate, and open to changing your mind. While this thread showed what happens when frustration takes control, it also exhibits the good side of this community, the willingness to try to help others and to learn and teach. Lets try to embody the latter going forward. Bottom line, personal insults are not acceptable. We are usually better than this.
I turned it off immediately yes.
I was sitting beside them as they were charging. have a tiny place.
Anyhow, it only took about ten minutes for the bad cells to go from 3.34 to 4.2 volts. The other cells never moved in that ten minutes.
Also, if the cells were not bad cells then the voltages would never go above 3.65 as the power supply is set actually so that they should not go above 3.5 volts. So blaming the BMS for the cells going above 3.5 volts is not good. The cells should never go above 3.5 volts if the voltage going into the cell is 3.5 volts.
Anyhow, I immediately stuck a balancing on the cells to lower them so they only stayed high for a very short time. But it is disturbing.
Thank you for watching the videos when you can.
Maybe that is why three cells have gone bad in only 3 months.
I got the old stock.
Dang
Dear Sherylin,
I just saw your email. No, I'm talking about the old version, but not saying that these are old batteries.
You use a BMS, but there is no a cut off relay. Did you turn off the charging after it turned on the red light to alarm?
Please stop charging now! The voltage of the 3pcs batteries has reached 4V, which has exceeded its maximum cut-off voltage: 3.65V. If you continue to charge, these batteries will swell, which will be unsafe.
If you use a relay with self-protection function, the voltage of these batteries will not exceed 3.65V.
The video link you sent is Youtube. Perhaps due to the restrictions of the Chinese network, I cannot open it. I know that it can be done using a special network. Regarding it, I need to ask my friend for help tomorrow.
I will reply to you again after opening the video tomorrow.
