murphylawe
Mad Scientist
Howdy All,
It's Murph here and I have just upgraded from a 24v AGM battery stack (8 AGMS @ 100ah each) to a 16-cell stack made up of 280ah LiFePO4 cells. I am using (2) Daly 150amp BMS units for control.
I am having trouble integrating the upgraded system, and can't get the batteries to top-off.
I am using a 4000w AIMS 24v Inverter/Charger and it is set up for Li-Ion. I am in contact with AIMS as this alone should take the stack to 28.8 v
The solar array is made up of (8) Trina 275w Solar Panels and feed into a MDT MPPT Controller. I have never had a problem with this controller and it too is set for 28.8v and for Li-Ion.
I can't image both are incapable of charging this stack to 28.8v and I am unable to get it above 26.7
SO... I am inexorably led to the DALY 150amp BMS units. I am including screenshots of the BMS settings, and an image of the my monitor. I have checked with a multimeter and all are correct +/- within 2-3/100ths of a volt.
Ideas or thoughts would be appreciated.
I replaced this:
With this:
Here are the BMS settings:
Protection Parameters Screen 1
Cell Volt High Protect: 3.65v
Cell Volt Low: 2.22v
Sum Volt High Protect: 28.80v
Sum Low Volt Protect: 17.70v
Diff Volt Protect: 0.080v D
Charge Overcurrent Protect: 225a D
Discharge Overcurrent Protect: 225a D
Cell Charactteristics Screen 2
Type of Battery: LiFePO4
Rated Capacity: 280.0nah
Cell Reference Volt: 3.2v
Sleep Waiting Time: 3600s D
SOC Set: 39%
Balanced Open Start Voltage: 3.310v
Balanced Open Diff Voltage: 0.050v
Collect Board Settings Screen 3
Collect Boards Num: 1
Board 1 Cell Num: 8
Board 2 Cell Num:
Board 3 Cell Num:
Board 1 Temp Num: 1
Board 2 Temp Num:
Board 3 Temp Num:
Temp Protect Settings Screen 4
High Temp Protect: 65C
Chg Low Temp Protect: 10C
Discharge High Temp Protect: 70C
Discharge Low Temp Protect: 0C
Diff Temp protect: 15C
MOS Temp Protect: 47C
I replaced this:
With this:
SOC Set: 39%
Board 1 Cell Num: 8
Board 2 Cell Num:
Board 3 Cell Num:
Board 1 Temp Num: 1
Board 2 Temp Num:
Board 3 Temp Num:
