Still over a buck a KWHR for me in fuel costs, plus the $2.50 for the box. I can get a lot of batteries and panels for that kind of money...
Or the efficiency. A small EFI gas inverter generator can hit a bit over 6kwh a gallon on gas (close to 7kwh/G). Yeah, propane is lower energy density than gas is, but this is hitting 7.69kwh/G. At $8k. Yes, it is silent.
A small inverter EFI gas generator does not have all of the fancy bells and whistles that could really increase the efficiency even more. Last I checked, EFI generators (in the portable size) are not running things like O2 sensors and MAF/MAP sensors, etc. They could be made quite a bit more efficient for not all that much expense. Probably not that hard to design one to hit 9kwh/G. Or a propane fuel injected generator with all of the bells and whistles at around 7kwh/G (or more). Yeah, it would be a lot more expensive, but WAY less than $8k. And a lot more power density.
I do kind of wish someone would come back out with a ~1000w propane only generator.
Anyway, a gallon of propane has 27kwh of energy content. A good ICE can hit 35% efficiency (carb portable gas generators are very inefficient ICE). Taking out generator inefficiencies in electrical conversion, you'd still be talking 32% or so (figuring about a 92% generator efficiency). That is 8.62KWH a gallon on propane. Now, that'll take much higher compression ratios, MAF/O2, EFI, possibly liquid cooling.
Talk to me once this is at least hitting 40% conversion efficiency, or just build me a high efficiency portable propane only generator for a much more reasonable price hitting 7-8kwh a gallon.
