propane auto changeover with generator
John Frum
Tell me your problems
Has anyone figured out how to do a propane auto changeover for a generator?
Just in case its not clear by auto-changeover I mean automatically switch from one tank to the other for extended operation.
Gotcha - wasn't sure. In any case the generator needs the right adaption parts to run on propane -if not manufactured for vapor based fuel. Make sure you properly size the regulator for BTU's of installed equipment.
Check Marshall Brass for that type of device.
https://www.marshallexcelsior.com/2-stage-excela-flo-auto-change-over-regulator-14-inv-x-38-fpt
Whole page of them on Amazon:
https://www.amazon.com/propane-auto-changeover-regulator/s?k=propane+auto+changeover+regulator
Have you seen or can you source a single stage changover?
So that I could use the existing 2nd stage?
Gotcha. Why not just tie all the cylinders together and let it run? I l know, I'm the same way, I'd rather have it so I could change cylinders out and stay running. The one mapguy525 linked looks like what you need.
I've been thinking that having 2 small inverter generators might also be a better plan.
Can sync them for more power or run one while maintaining the other.
Engineer775 on youtube did a video where the house backup was 2 or 3 honda generators, all propane setup. They could tie in 1, 2, or all 3 gennys at a single time.
I like propane as it stays good forever. Could you just put a 2K tank out there for the genny?
I want the solution to fit in the bed of a pickup.
Oh and every piece should be lug-able by one guy who is getting isn't as young as he used to be.
Stick with "inverter" generators. Lots of brands to choose from. Many people love Honda but I think they are overpriced.
The biggest generator you will find that is ACTUALLY "lugable" is the Westinghouse iGen 2500. It is a few pounds heavier than other 2000w-2200W generators, but still can be "one handed". No factory LP hook up.
2 generators is a great idea if your pocketbook can handle it.
