Proper way to earth/ground solar panels, grid tied, on a home?
Davehal9000
The more I search the net the more conflicting info I get. I know it's a complicated discussion as everyone's setup is a bit different, and the codes running all over the place.
I have a small system, 4 each 250w panels, up on my home's roof. 2400w inverter with a 24v Hawk battery.
I have daisy chained the panels and rails together. I have a 6 gauge bare copper wire running to the ground below, under a rock bed a few feet, and fastened to the home grounding rod. Is this the right way to earth/ground the panels?
Should be fine. If you obtain a local permit and inspection you will know if it complies with all local rules.
