SunRunLandYacht
WonderYonder
Proposed 24v Solar System for fulltime retired explorer couple with 35’ 50amp Motorhome RV (mh). I think this setup will handle the majority of our living environments or we will adapt &/or change altitude. I am new to solar and would very much appreciate constructive advice and suggestions. I want to do this right, the first time and feel safe sleeping with it.
Solar Panels = 2800w: 7- 400w Trina or other 40”x 80” 45v @ 9.74a solar panels. Six mounted above roof of the mh and one deployable on roof of tow vehicle. All panels will be wired in parallel (45v @ 58 to 68amps) to minimize effects of shading at, available boondock campsites in National Parks or other. Solar is maxed out so usage will be adjusted as needed.
24v Solar Controller = Victron 150/100 or other that will handle the 68amp input with safety margin. Are there better alternatives?
Battery Bank = 2 – Big Battery 24v 170ah Power Blocks in parallel = 8kWh already ordered and shipping 11-20-20. Might add another Power Block or cut consumption as usage dictates.
Inverter / Chargers = 2-Victron (or ?) 24v/3000w inverter/70a charger MultiPlus (have a 2-way transfer switch between shore power and Onan GenSet) or maybe MultiPlus Quattro (at times will be plugged into full or limited shore power). Believe these can be wired single phase, with parallel communication to second unit that will turn on and off as 120v usage exceeds output of single unit or I can install them in split phase if determined to be best. These units are very efficient and I have read that alternatives are less efficient, noisy fans and have other issues. I think I may need 2 Current Surge Limiters for the inverters and 2 micro starts for roof air-conditioners (intend only limited use of one, if necessary)? The only drawback to Victron equipment, I see, is the cost but I do like the inter communication and monitoring between the equipment components. Please advise as I am without a money tree.
Orion (?) 100amp 24v DC to 12v DC converter for house lights, h2o pump, etc.
I believe the alternator on my Cummings diesel is currently used to provide 12v DC operating circuits, charge the two flooded start and 2 AGM house batteries, etc. The AGMs are currently used to power a 1kw Xantex Inverter for limited overnight power and to keep the ice maker going while traveling and will be removed along with a newish 70amp 12v Progressive Dynamics converter. I think I will be able to install a small 12v DC to 24v DC step-up inverter ?/ converter to provide limited charge to the LiFePo4 battery bank enroute. I do not want to damage my alternator and can charge bank with generator + dual 70amp Victron chargers; if absolutely necessary. I hope this system can, otherwise, make the GenSet useless and removable.
Monitoring: Have TR-16 with 500amp shunt (sampler) on AGM negative now. Will probably be installing a Victron BMV-712 battery monitor with bluetooth but need to research more and look into needs vs wants and other options like the Victron Color Control, Octo GX computer and what you suggest. I want to be aware of system condition and safety, always.
I know I have asked a lot and there are many things I have not covered and questions not asked, so your help and suggestions will be appreciated. Much thanks in advance and stay safe! Mike
