Hi all,
Anyone see a problem with this?
Situation:
Off-grid cabin. BC Canada. Unoccupied for a few months a time in winter, with temps going to-25deg C (-13 deg F) for weeks at a time. 2x6 insulated walls, 160 sq ft cabin.
I've got 2 strings of 4 x 460W panels (one ground mount, one on roof), connected to the separate MPPTs on the EG4 6000XP inverter (which will be "Off" so no parasitic drain, just serving as solar controller & battery charger during winter), to charge 14.3kWh EG4 PowerPro with built-in heater (which pulls 200W-220W apparently, when running). I'm worried snow will accumulate on roof panels (~22deg incline) or not enough sun on my ground mount (45 deg incline, but partially shaded throughout day), and not enough solar will come in on a "weekly" basis to keep the PowerPro's internal heater going all winter. I was going to build an extra insulated box around the battery (to minimize heat loss from internal heater), but am also worried about 6000XP operating in those temps as the MPPT controller.
Plan:
I want to use a cheap 12V PTC heater (THIS or THIS), running off a single separate vertical 200W or 460W panel, through a separate 30A MPPT cheap solar controller's LOAD output (so no 12V battery involved), to heat a small area to help keep my inverter and battery warmer, reducing catastrophic failure if PowerPro drains down, or 6000XP malfunctions in the cold. I'm thinking of putting the PTC heater in a metal bucket of sand, or bunch of bricks, inside the cabin. The idea is that it would increase the air temp in the cabin some amount (or maybe just a smaller "closed" sized enclosure (with 6000XP + PowerPro inside).
Worries:
Cheap 30A MPPT solar controller malfunctions and burns down cabin.
Cheap PTC heater malfunctions, or wires get hot, and burns down cabin.
PTC heater doesn't pull enough load once warmed up, so cheap 30A MPPT controller overheats and explodes and burns down cabin.
Other?
Your thoughts?
Thanks kindly
Situation:
Plan:
Worries:
Other?
Your thoughts?
Thanks kindly
