Pure Sine Wave 3000W Inverter and red zone EMF
IanInShawnigan
Shawnigan Lake
Just curious if anyone has run across this.
I bought a Renogy 3000W PSW Inverter to add to my off grid system specifically to run my fridge and freezers.
My system is in my basement under the living room.
I noticed in a week that my cat would move away from her favorite spot on the couch when the fridge powered up.
Then my wife kept moving off the couch and complained of heart palpitations.
I bought a multi-meter and began checking out what was going on.
As it turns out, when the 3000W PSW Inverter powered up it puts off around 256 milligouse at the unit and upstairs in the living room, around 15 feet away, it was emitting around 60 milligouse, which caused my meter to register RED/SEVERE DANGER. WOW! Safe is 2 and under.
I turned off the Renogy 3000W PSW and I am now using an Eliminator 4000W Modified Sine Wave Inverter and I will be adding a 2000W MSW Inverter as well.
I know that PSW is best for appliances but the EMF/EMR is obviously extremely dangerous to the body.
With the MSW Inverter the reading is ZERO in the living room and low at the unit itself.
I built this myself with the guidance of Will's videos mostly. Prior to that I knew nothing about solar systems.
My 100% OFF GRID, self built system contained in my basement, is constructed of 6 Renogy Rover 40A Li MPPT controllers.
Each controller is hooked up to a 450W split cell (72) monochrystaline panel; 6 panels, each is independent from one another.
They are all hooked up to 1 battery bank. The system is grounded to the old grounding rod for my house that was no longer being used for the new breaker.
The battery bank has 18 - 6V AGM in series and parallel to make 9 - 12V, 250Ah for a total of 2250Ah and 1125Ah at 50% usage. With AGM there is a 50% rule. The safety factor is what is the most important thing.
AGM is the safest and best way to go I believe from the solar experts I have spoken with. No off gassing or risks that lithium batteries have. I use this system primarily for 4 small freezers and the fridge. I am adding another 8 - 6V (4 X 250Ah) to the current size for year round.
All 6 controllers are set at the auto identify factory setup as 12V, SLD. I have not changed anything in the parameters.
I think I'd move up a tier or two in quality.
Hmm. Do you think that would actually make any difference? Any particular suggestion for a SAFE unit?
I would advise anyone using a Renogy PSW to never use it in an area closer than maybe 50 feet away from you in an enclosed and shielded area, that is for sure. Putting out that much radiation is likely to kill anything near it or exposed to it for very long.
I see a lot of people using these things in their RV's or vans. What they don't know will kill them.
Obviously I am not going to go out and buy another PSW by any manufacturer unless they can provide proof that their unit puts out ZERO EMF/EMR at 4 feet away. Anything more than that I would consider extremely hazardous to health.
Either rip out all the wiring in the house, put up with it, or buy better equipment, but the wiring is still going to create EMF.
The E is for electro, hard to get away from and still watch TV or go on internet forums.
Yes. There are 1000s of studies supporting the EMF disease paradigm. Elon Musk has a titanium plate to hold his vertebrae together, and takes injected drugs for to keep his obesity down. Steve Jobs was living 24hrs/day at Apple research headquarters.
Test the paradigm yourself by sleeping next to an inverter, smartmeter or electric fan. Put a smartphone near your nose and likely you will sneeze from sinus irritation.
If you have rashes, insomnia, backache or depression, then, review your EMF environment. You don't have to wait for a news anchor to clue you in.
