harrymanimus
- Apr 3, 2021
- 49
I have 2 products. An inverter for my car, and an EcoFlow Delta Portable Power Station. My goal here is to charge my EcoFlow Delta (also have a Pro version on order) from the car inverter in a non detrimental way to the life of the EcoFlow product or battery.
Inverter Product:
PSW, THD listed as 3% or less
This inverter is a 60-0-60 split phase.
I bought a Liumy Waveform Wultimeter so I could inspect the wave and ensure it is not a modified sine wave.
Pics below of inverter wave. Thoughts on what the sine wave is showing? Does this look like < 3% THD? Is this bad to use for any types of products?
I have another related post to this here, where I was trying to figure out how to run my central heat with my EcoFlow box with some related posts for the inverter. I have whole home (120v only) working now off my EcoFlow, I'll add that to the old post.
Inverter Powering Nothing:
Inverter Powering Space Heater:
Inverter Powering EcoFlow 1.1kw draw:
Inverter Powering EcoFlow 767w draw:
Inverter Product:
Handy Power X HPX1530INVCBLBG Power Source 1500W/3000W
Description Specifications WHY BUY A GAS INVERTER or GENERATOR WHEN 3/4 OF ONE IS SITTING INYOUR DRIVEWAY RIGHT NOW - YOUR VEHICLE.Add the weather resistant HPX to the vehicle you already own, and together, they will give you 1500watts running (3000watts starting) of pure, AC power without the...
handypowerx.com
Inverters - bonded/floating ground and reversed hot/neutral
I have two products with inverters that failed to run my home furnace during the Feb winter storm. I had to run a small space heater which was just passable to keep our bedrooms in the 50s. I was super close to being ‘hero level prepared’, but no cigar. After some research, I determined that...
diysolarforum.com
