I've got a 271Ah Lishen 4S pack with a JBD 120A BMS. Working pretty well on my boat, powering the fridge and induction cooker, charged by solar via a 40A MPPT with 520w of panels. The other charging source is a 30A mains charger.
I also happen to have a small drop-in 60Ah from Sterling. I bought this as a bit of an experiment when I was using a trolling motor, and it just isn't getting much use any more. So I was wondering about adding it to my existing system, and if so, how?
The Sterling can charge at 30A and discharge at 60A. It has no communications facility but I can look up the preset BMS parameters and presumably adjust my MPPT settings accordingly.
What will happen if I set up the drop-in in parallel with the larger battery? I'm particularly interested in the ability to draw a larger current.
