sunrise
- Jul 16, 2020
- 206
In my small trailer solar (240w, in parallel) setup, I have a 20A auto-reset thermal breaker and a 32VDC switch between PV and a Victron SmartSolar 100/20 SCC. I want the switch so I can disconnect PV when it's not needed so it doesn't keep my battery at high SOC. I thought this was fairly common, AMSolar even have this kind of setup diagram on their website:
Yesterday I came across this video and now I am a bit confused and concerned if this is the right thing to do:
I am wondering when my switch is disconnected, if the floated negative wire from PV to SCC could damage the SCC or cause other problems? The Victron SCC has separate negative connectors for PV and battery, and there is a grounding screw on the SCC heatsink but I did not connect the grounding screw. Also my 12v panel ground busbar has a copper wire that is screwed onto A frame.
Thanks in advance!
Charge Controller Kits
RV Solar Panel Controller - At AM Solar we have RV Solar panel controllers and RV Battery charge controllers.
amsolar.com
Thanks in advance!
