130 volts is the max voltage the inverter can handle. You need to arrange your panels wiring either in series, parallel or a combo of both to get close to your max inverter input voltage to be as efficient as it can be.
Also add up your amps of the panels in your config to see if itscover 80 amps.
There are solar system calculators on the net and on here (I think) to help you size your system.
