Shale MacGregor
- Sep 5, 2021
- 641
Panel short circuit current rating is 3.84A
Panel series fuse rating 15A
Combiner using 15A fuses with 7AWG
Panels hooked up with 10AWG Wire
Can I combine multiple strings in parallel into a single fuse, and if so how many? My logic is that each string can't produce more than 3.84A, so even if all 3 strings went into full short, no more than 11.4A would ever cross the wire. This would allow me to take my 6 string combiner and instead combine 18 strings instead.
My issue is that so many MPPT are 150VDC or 200 max, and my panels are high voltage low amperage so don't work well without running a lot of parallel (it would take 10 strings in parallel just to max out a 40amp MPPT)
Thanks!
Thanks!
