efficientPV
Solar Wizard
- Sep 24, 2019
- 1,764
A PV heating for chickens to melt ice was posted a while back. It didn't really cover the issues in doing this
The resulting solution the OP went with was a 12V 50W panel and a silicone pad rated at 24V 80W that was 7.3 ohms. I didn't think that would be enough given winter conditions. Since then I have been contacted by another trying to do the same thing with a 200W12V panel and a 1.5 ohm heating element that wasn't working well. That element has since been replaced with a 4.6 ohm element. Results at this time are not available but he did provide a chart for power production at different currents. Unfortunately, the chart starts at 2A which does not reflect probable low currents less than 2A. A 10 ohm would work better.
All solar is local. I just started testing with my winter conditions with a 100W 12V panel I borrowed and currents of less than 0.8A are common. 0.8A and a 7.3 ohm element = 4.6W. A 50W panel would be half that current and be about 1.2W. My guess is it takes about 20W to be successful melting ice. With direct connect heating element resistance should be designed to top out at about that power. A big panel is needed just to supply that much in winter. I was working on a simple LM358 op amp design that would be cheap just for 12V panels. After posting the design I was sent this video.
While that poster has corrected some of the design is shows the simplicity. This as well as my chicken heater can be used on any array voltage and wattage with some component changes. Here is the one I built, only 15 parts.
In the test setup with a 12V 100W array the power was only about 6W. This is winter and that does help. It demonstrates the need for a power point control in this application with just 0.3A
Somewhat of an off-grider/homesteader question, but this sub forum seemed most appropriate.
Any reason I can't take a 50-100 watt panel and directly wire it to DC heat tape to help keep water for chickens from freezing during the day? Not asking about effectiveness, just whether the panel would actually turn on the heat tape intermittently as it gets sun or not. I wasn't sure if some logic was needed for panels direct to appliance.
An example of the heat tape:
DC heat tape (amazon)
- eson
- Forum: Danger Zone! (Advanced User Experiments Only)
