5
52388
Guest
Hi, I have a Voltronic solar inverter (24v 3kva, 1500w pv with mppt range 30-115 vdc) and one 320 watt solar panel (vmp 37, imp 8.65).
My issue is that I have a lower input reading from my panel than expected, peaked at around 180 watts, but the actual readings on a clamp multimeter were 32 volts + 8.5 amps, that gives out 270 watts. I didn't have this issue with a different but 12 volt inveter, it gave out all that power.
Is the voltage not enough for the mppt to start tracking or is it something else?
BTW, Occasionaly, after a cloud emerge and then pass, the input spiked 210-215 watts for a short time.
I live in Gaza and solar panels are out-of-this-world expensive so I need this to give all the power it can.
Thanks.
Thanks.
