The tilt on my fixed array is set to average year round. Spring Equinox was over a week ago, but because of being busy and weather, etc, I've not really been able to observe it's performance during this optimum time until today.
The particulars:
Six 405w Trina bifacials, seriesed to feed the MPPT controller in an EG4 3kw 48 AIO. My little battery bank is four sereiesed 12.8v 100ah Dumfume LFPs. Temp outside was about 75f at noon. Before noon, I partially Drained battery with PV off before checks to insure the panels were putting out at peak sun. These are bifacial, but get zero back lighting. Sky is sporadic clouds, air is high humidity/tad hazy and the array is a little yellow with the pollen explosion this week. I was taking readings between sneeze fits.
At 12:30, I shut off the draining load (1500w space heater), then turned on the PV. Between the passing clouds, the highest wattage spike from the panels I saw on the EG4 readout was 2150w. Shunt was floating just under 40a going to recharge battery bank.
I'd preferred the panels be squeaky clean, 33° and the sky as cloudless as our Moon, but you take what you get.
Theorectical output is 2430w, but it was 2150 at test time. Is that OK? Thanks.
The particulars:
