Need a way to limit PV string DC voltage to that allowed by a hybrid inverter.
Unique scenario. Imagine a situation where you are unable to change your panels or the string size of the panels (permits, zoning, etc) and you need to limit the DC voltage to a lower value than the string can theoretically produce. If your existing inverter strings theoretically can produce up 550V DC on a cold sunny day, and the current inverter allows 600V DC you are okay. But what if you want to switch in a hybrid inverter that only allows 500V DC per string? You are okay 360 days of the year, but a few winter days might exceed the inverter string voltage limits.
Is there a way to limit the DC voltage of a PV string to protect the inverter on those few days it might be a problem?
