Dallascowboy
- Jul 23, 2022
- 4
I have a 3 panel PV system with panels rated at 250W and 36V each connected to a MPPT charge controller and 2000W inverter. The solar array is panels connected in parallel. The maximum output I have been able to measure so far is 350W. I have noticed that when it is under a connected load (such as a small portable air conditioner), the voltage drops to like 14V (at about 24 Amps). Not sure what is going on and how I can get as close as possible to 750W at 36V.
I do not expect 100% efficiency by any means, but currently I am at less than 50% efficiency. The data shared here is under full sun exposure. Any help or suggestions to troubleshoot will be much appreciated.
