PV Testing Equipment?
dmkjr
South Carolina
I've seen a few low cost testing equipment with MC4 connectors that test PV output of solar panels. I've seen a few variant with 400w, 800w, and 1600w editions. It looks like it will provide VOC, max watt output, etc.
Are these worth the $75-125 they cost? Is there better equipment? Anything I should be aware of? Can think this will help if trying to determine a power output issue.
I would guess the utility is limited without being able to compare the output to a reference cell.
There are plenty of expensive testers out there such as https://www.tequipment.net/HT-Instruments/I-V-400w/Solar-Field-Analyzers/?b=y&v=74532
If you are going to properly commission a system these tools make sense. For troubleshooting or diagnostics I am less convinced.
How about short circuiting a panel by connecting the pos and neg wires to each other. Then use a clamp ammeter to clamp around one wire to read the amps flowing.
Thats my plan. Also thought about making a connecting wire with mc4 connectors and literally wire the VOM in series with the panel leads. My VOM clamp is less accurate then testing amps with the vom cables.
I butt spliced a pair of MC4's to a set of meter leads so I don't have to try to get the conductor right on the pin.
This works fine for voltage.
Shorting and clamping works fine for current as mentioned above.
IMO, having to switch modes on the meter is a PIA and spending $60 for one that does both is nice.
A friend has one of the elejoy testers. It "seems" to work fine. I like how it automatically comes on and tests.
When I buy mine, I plan to get the biggest one, as his small one can only test a single panel before it shows OL.
What I really want is an (affordable) meter that measures Irradiance. The Fluke IRR1 is pricey. I know it will work perfectly and last forever, but.... I don't want to cry once for it.
Use multi-meter to test voltage. + meter probe into + MC4 and - meter probe into - MC4. Don't worry if you get them switched...there will just be "-" in front of the reading.
Use clamp meter to read amps. Connect MC4s together and use clamp meter on the cable to read current.
