I don't know how you can match anything when using those elements. 600 / 12 = 50 Amps and 600 / 50 = 12 Ohms.Good Morning, new forum member but I've done several off-grid solar systems on campers and RV's.
I'm getting mixed answers both in researching other threads on here and from solar panel experts. Setting up a hot water heating system in Hawaii, where freezing temperatures are not a factor but the degradation of a thermal solar tank on the roof doesn't last is, and is too much weight for the area we want to install it. We've resolved to use a regular Rheem hot water heater but swapping out the AC elements with Dernord 12v 600w DC elements on Amazon. Two of these powered directly by two 400w panels on the roof (800w total to each element, 4 panels total) with 50a breakers on each element circuit.
We only want water to heat when the sun is out and are trying to avoid using charge controllers, inverters, or storage.
My question is two parts:
a). Are we adequately matching panels to the resistance of the elements?
b). How can we thermostatically switch these without arcing?
My first thought would be the use of heavy duty solenoids wired to a thermostat, maybe with an intermediate relay if the switching power of the thermostat is too low.
Two of these: https://a.co/d/6I7WmmL
And one of these: https://a.co/d/iC9VX6m
Any thoughts or advice are much appreciated.
Let me explain something that I accidentally discovered about 3 years ago when I was testing some 3 year old panels. It was not my goal in life to use solar electric to make hot water. I headed down a rabbit hole not knowing where it was going to take me. It order to understand this it is necessary to be able to let go of something that I call " Grid think mentality "Pardon me, I'm trying to understand the impedance (including an element in the mix) of using the panels in series vs running the panels in parallel. I'm worried about the safety and efficiency of the system. But I think you're right- I'm thinking too much about this. My math took me down this rabbit hole:
Vmpp is 42.1v
Impp is 9.51 amps
With 4 panels in series I have 168.4v total Vmpp. That makes my total Impp still 9.51amps, right? So MPP resistance should be around 17.7 ohms. And so my guess (and per your suggestion) is that a lower wattage element (like 2500w) to series-connected panels would be better than running in paralell with a 48v 1500w element, like the one I posted from Amazon.
I'm bypassing the AC thermostats because of the risk of arcing. Correct me if I'm wrong, but that poses a safety risk if the system works TOO well (fat chance, it seems). So all I can think of is to make sure the pressure relief valve is working and piped outdoors. I'm also toying with the idea of using a local 120v outlet to power the thermostat which would then control a DC relay to switch the PV supply on and off, but maybe that's just another rabbit hole. Either way, thanks for your help. I'll tie 4 panels in series to 2 4500w elements in series and see how it goes.
When the solar panels produce about 40 volts each then your voltage is 160 volts. With a load on the panels that is going to drop to about 150.You were told what to do, why do you cling to this 48v idea? Connect 2 existing 240v heating elements in series directly to 4x panels in series. That should give you 1200 watts of heating power in direct sun. Make sure to disconnect or bypass thermostat switches or they will arc and burn up when they open the circuit and that could start a fire.
Vmp at 50°C panel temp should be 39V at 10A load, and with 4 series panels + 26 ohm resistor load would be < 10A and voltage will be > 39V, likely 41V = 164V²/26 = 1034W in full sun. That may not be good enough for you but that should generate 22°C of heat gain into 50 gal tank per day (assuming no thermal loss). That's enough for 2 people to take showers and do dishes.When the solar panels produce about 40 volts each then your voltage is 160 volts. With a load on the panels that is going to drop to about 150.
The resistance of a 4500 watt element is 12,8 Ohms and increases to about 13 when it gets hot. That would be 26 Ohms of total resistance.
Ohm's Law states that the voltage squared divided by the resistance equals the wattage.
That would be ( 150 X 150 ) / 26 = 865 watts of electrical output that gets turned into heat.
( 865 / 1200 ) X 100% = 72% output. That's not enough of an output for me to want to do as a project.
I am looking to get a number closer to an 85% output.
240 volt 5500 watt elements are 10.5 Ohms and probably 10.7 when hot. That would be 21.4 Ohms.
The output voltage of the panels will most likely drop to about 145 because now they have more load on them.
( 145 X 145 ) / 21.4 = 982 watts and a gain of 117 watts. ( 982 / 1200 ) X 100% = 81.8% output.
982 watts is almost 1 Kilowatt and 3350 Btu's of heat going into the water.
I was able to boil a gallon of water in about 10 minutes only using 450 watts coming from two 265 watt panels wired in series.
I was able to do that by matching the heating element to 85% of the panels maximum power point.
Your mistaken, you put 3 panels on a tracking mount and you get 85% 12 hours a day in the summer where I am located.If you want better than 85% output, you shouldn't do direct connection for water heating. The person who came up with this label IDEAL RESISTANCE should be shot. You only get that for an hour of the day at best and under ideal weather conditions. Go back and do some math at 70%, 50% and 30% current. It is the power of squares that kills you with direct connect. When I get these currents with an array I'm feeling good. There is a great penalty for going ideal resistance and under, very little penalty in daily power for going over ideal resistance. 85% is an optimistic value to shoot for. 70% is more realistic. Those elements in series will produce a lot of hot water in this situation. Series will not be ideal as the top will get too hot. Better to put a higher wattage element in the top (lower watts in series) and lower wattage in the lower section (that produces more watts). Absolutely he will need thermostat control with SSR.
If someone posted charging a battery with PV and a knife switch, everyone would respond with righteous indignation. But do stupid direct connect water heating and everyone says, meeee tooo!
You said that you are in Hawaii. Can you tell me how they are charging you for electricity now? Is it so many Kilowatt hours at 40 cents each and then the rest at 55 cents? Do people get $800 electric bills?While not Solar electric, have you considered either of the following 2 ideas?
A cheap Propane on-demand hot water heater instead. Propane for this would probably cost $22 a tank at Walmart/Lowes/HD and would last a month or two for showers, etc. You would need either an A/C supply for the burner or some igniters use a battery.
Throw a long garden hose on the roof and let solar do it's thing. Well, maybe a couple hoses. I get scalded from hose water left in the sun for a while.
Luckily here in Hawaii the temp of water is either 70 degrees or so minimum where mainlanders could have 55 degree water supply to their house.
Yes it is but I don't have those numbers handy at the moment. I am a very light user. With the exception of stove and dryer and perhaps a light use of an appliance or two which are still on the grid, my consumption is something like 400 watts. While not yet fully set up, my usage from the utility is dropping.You said that you are in Hawaii. Can you tell me how they are charging you for electricity now? Is it so many Kilowatt hours at 40 cents each and then the rest at 55 cents? Do people get $800 electric bills?
Or get 500A 900V 1.5w 12v coil contactor for $15.You can get a 30A 900VDC rated contactor with a 12VDC coil for less than $60 online
I don't think that you are going to have any problems.I like trying ideas out.
This past weekend, I hooked a 3500 watt element up to 4ea. 460 watt bifacial panels in series.
Cold clear weather, got 163VDC under load, 9.4 amps, 1,532 watts from the element.
3S2P, same panels would get around 2100 watts from the element.
Either will definitely heat water if it is on for long. As long as it gets sun, it will produce some heat.
You can get a 30A 900VDC rated contactor with a 12VDC coil for less than $60 online.
The coil draws around 0.5 amps, so I would not be afraid to run a $10 12VDC plug-in transformer through the water heater
thermostat to power the coil.
I seriously doubt 6 DC watts would destroy the thermostat.
PV power to the lower element, household power to the upper element, in case the PV isn't enough.
A 675 watt output is enough power to heat 44 gallons of cold water to 125 degrees in the summer, each day, for about 5 months.
Using an electronic device keeps people in solar groups from learning how electricity works. They use a plug and play method of snapping connectors together and then hoping for the best. It not an optimistic value because its been tested and it works.
It will not work in the winter because there is a reduced number of hours in the day and clouds.
The assumption in solar groups has always been that if I can't do it then no one else is smart enough to do it either.
My background is not in solar. It is in electrical experimentation.
Solar is a very small part in the entire electrical industry.
Battery charging is what needs MPPT controllers because the controller has a charging program that it uses and it decided whether it wants a 50% output coming into the batteries or 100%. It controls the charging program and not the panels.
I only do experiments in the summer because there is not enough power in the winter to do anything with. It would be like buying a race car and then testing it to see whether it can go 30 miles an hour. I am interested in going 150 miles an hour.There was a nice video where panels were aimed every 15 minutes and he got amazing consistent results thru ought the day. I thought that was misleading to many who would think the same results with fixed panels. I have some east facing panels and they supply 70% of my daily energy. 99% don't track as that is costly and limited to those who have a lot of space. It still doesn't account for clouds, something you just give up on. I have certainly known for years there is very little technical talent in the solar world. Actually, resistance PV heating needs power point far more than battery charging the solar world doesn't understand that. Maybe you should experiment more and see what panels produce in a fixed setting.
The following is a post I made elsewhere for a guy with chickens wanting to melt ice. I think it is a good example.
All solar is local. This morning it is 8 degrees, overcast and there is a slight dusting of snow on the panels. At home I have
a 450W 60V array for supplemental heat to my heat pump water heater. This is mostly for product development, my summer home is all solar.
At this time the system is producing 0.25A @ 60V or 15W. This is lower than usual but in winter getting 40 to 70W (15%)is not.
I removed the snow about an hour later and current increased to 0.96A (58W). The current rating of these panels is similar to yours.
You design for the bad days. Good days take care of themself.
Suppose your panels and element can only produce 1A on a winter morning. This data can be verified by measuring element voltage in the morning.
1A X 1.5 ohms = 1.5V Multiply that by 1A and it produces 1.5W.
2A X 1.5 ohms = 3V Multiply that by 2A and it produces 6W.
3A X 1.5 ohms = 4.5V Multiply that by A and it produces 13.5W.
That 200W panel hasn't provided a lot of power but it was needed to get that much current. Panels are current sources.
This range of current is typical for winter. Days with more sun likely wouldn't need a heating system. This may struggle in winter.
Let's substitute a 6 ohm heating element
1A X 6 ohms = 6V Multiply that by 1A and it produces 6W.
2A X 6 ohms = 12V Multiply that by 2A and it produces 24W.
3A X 6 ohms = 18V Multiply that by A and it produces 54W.
This system will peak at about 70W because resistance will limit voltage to about 23V, the open circuit voltage. My guess is 20W is needed to melt ice.
This looks fairly successful.
Finally a power point system where winter panel voltages will be about 21V and stay there regardless of current.
1A = 21V Multiply that by 1A and it produces 21W.
2A = 21V Multiply that by 2A and it produces 42W.
3A = 21V Multiply that by 3A and it produces 63W.
This is magnitudes more successful. The new problem is a temperature control system to prevent the water from becoming a bacterial stew.
With 200W you could boil the water. A power point control can operate with a 1.5 ohm element. Pulses are always the maximum current of
15A. It operates much like a light dimmer using duty cycle to control power. The electronics is just easier to build with higher voltages.
I accidentally discovered how to make this all work when I was testing some used solar panels.Good Morning, new forum member but I've done several off-grid solar systems on campers and RV's.
i have a 7 panel string (240vdc) (400w bifacial panels) going to a 2400w (24ohm) hot water storage service. The thermostat uses a/c and a contactor with 3 contacts in series and a 50watt light bulb. That way there is no dc ark to extinguish as a lamp when “cold” takes care of that. The contactor also has 1 normally closed contact that i will use to run more power (mainly cloudy days) back to the battery bank via a high voltage mppt when the heater is hot.Good Morning, new forum member but I've done several off-grid solar systems on campers and RV's.
I am not sure what the fascination is with 12 volt heating elements. Your 12 volt 600 watt element has a resistance almost equal to zero.i have a 7 panel string (240vdc) (400w bifacial panels) going to a 2400w (24ohm) hot water storage service. The thermostat uses a/c and a contactor with 3 contacts in series and a 50watt light bulb. That way there is no dc ark to extinguish as a lamp when “cold” takes care of that. The contactor also has 1 normally closed contact that i will use to run more power (mainly cloudy days) back to the battery bank via a high voltage mppt when the heater is hot.
I'm pretty surprised he has posted that schematic as he had abandoned trying to resolve the design issues with that circuit and left everyone to fend for themselves. Without a doubt, that is the worst hot water design out there in terms of blowing up, inefficiency, and inconvenience of use. That design is a total joke.Any schematic to work from?
