astrofisher
Google search can be frustrating. I'm doing a small solar project (my first) and am getting ready to mount a couple of ground mount panels and run wire to my small tool shed. I have a few rolls of 10AWG THWN wire and was thinking about using that in conduit from a PV disconnect to the shed. The first result Google listed:
Then — the very next sentence: "THHN wire has a small insulating layer on the conductor, and that insulation is fine for lower voltage solar panel setups."
And then: "This could cause some problems, though. The solar panel voltage is around 15 volts, but the power company’s grid has 120 or 240 volts of alternating current."
Anyway, back to my query. In a similar situation to mine, is it common practice to switch to THWN and run in conduit back to the building?
