k490
I want to use 2" knock out not being used on the side of my main but can't find a 2" 90 deg elbow plus 2" rigid parts is really expensive. PVC 2" along with a 4x4x4 box is lot cheaper plus I can connect other conduit to it. I only need to go though block wall into my garage about 6" thick. Inside I would go right into a wire trough from what I have read all I have to do is bond the ground wire between the two boxes main and the wire trough. How big of a ground wire do I need to use I will have several wires going through this conduit including PV wire.
