Hi, I bought a few QUCC BMS boards recently. I am using it for 14S, 200A. I have a strange issue with cell-1 voltage in all these boards. The voltage is read correctly until the circuit is closed. Once it starts discharging, the cell one voltage discharges faster than all the other 13 cells and triggers the under voltage protection. As soon as it triggers the protection and DSG_FET goes off, the cell reads correct voltage again which is way above the under voltage protection value. If my wiring was wrong it should be reading wrong voltages also when the load is cut off, which is not the case. The official site has wiring for 20S, 16S, 12S but not for 14S. I took the available wiring diagrams as a reference for 14S. I have attached the wiring diagrams. Can someone please verify if that looks right? I don't really understand how the reference changes as soon as the circuit is closed. Or why it reads incorrect voltage only on the first cell.
