Question about Drok Battery Capacity/Load Test Meter
Hello Guys,
I'm so happy that I found this forum with a lot of useful information.
I would like to ask people who have Drok Battery Capacity/Load Test Meter, if the device can measure bidirectional current and to be used as battery monitor. I'm a bit confused, because on amazon description says that it is bidirectional, but on the @Will Prowse web page of battery monitors, he stated that if it show zero current, you should flop the hall sensor.
If I cannot use it, will go with chinese Victron battery meter.
Chinese Victron ? Victron is from the Netherlands.
I have manage to burn out the relay transistor on the hall sensor unit. Is anyone able to tell me the transistor that I need to replace it as mine has melted and I can not read it or will another spec transistor do the same job . I am new to electronics so please don't be to critical. many thanks
Ohh did it not come with a manual? Have to read manual, lots of random details.
Hardest setting to find is setting it to zero. Press the down arrow till it's at lowest selection that can't be seen, then press ok. Really weird reset method and hard to find in instructions.
BEEN TRYING TO FIGURE THIS OUT FOR 2 DAY! Thanks Will you rock!
I just got one of these, seems to work, but the ah and wh don’t go up. I’ve reversed the direction. Any thoughts?
