ericfx1984
- Oct 10, 2021
- 740
Okay.. so I have a question about parallel battery Banks...
I am going to be building a pair of 4s, 230 amp hour Eve cells (so a total of 8 cells)
Each one of these 4S packs will have a 200 amp BMS
The plan is to join the BMS positive outputs together.. so I'm wondering should I have a jumper of appropriate size connected to the BMS and then jumping over to the other BMS? And then running my leads off from there or should I purchase or build a bus bar that can handle in theory 400 amps? I figure I can make one out of either copper or potentially aluminum but I'd like to avoid aluminum...
I guess what I'm asking is what is the best way to link parallel bms's?
Another way that I was thinking I might be able to make this work is to simply run two separate lines, one off of each BMS directly to the inverter.. in the middle of that I will have a 200 amp ANL fuse on the inverter side of the ANL fuse
