jjosephiina
- Feb 8, 2022
- 16
Recently finished setting up my solar to my roadtrek, and hooked up my 800w system (80a charge controller, 3000w inverter) to my class b’s existing system using a 30a Automatic Transfer Switch and wiring everything together like this [video](https://youtu.be/jpICwTtAV_I) while also disabling the class b’s old converter. While the inverter and charge controller work perfectly while it’s all plugged in, all my AC appliances worked good, minus my air conditioner, it turns on for 1 sec and then turns off immediately. And none of my DC works. I’ve triple checked to make sure i wired everything correctly and not sure what i did wrong. My goal is to have everything connected to my class b vans older AC DC panel to be solely powered by my solar system, using my new ATS. (without rewiring everything)
What did i do wrong?
