Easty
- Apr 9, 2020
- 14
This is something I've struggled with for a while though it's only the winter months when I find I have not yet discovered a solution.
We are in a full off-grid configuration and when the sun gets a little timid we use a 9500W Predator inverter generator (hooked up on both legs to the Sol-Arks Grid input) to replenish the batteries.
The issue I have is the need to limit the charge rate with the assumption while we are charging a large load from our appliances will trip out the generator. The predator has a manual trip and this means a walk out to the unit to reset everything, our older westinhouse had a more soft trip mechanism and this would reset automatically after a few minutes.
To prevent the trip scenario I limit the charge rate to about 95amps using roughly only 5kw, rather than the generators 7kw continuous rated load, this means an annoying gen on for a longer period which is never a fun thing.
My desire is to somehow have the load from the generator limited to 7000KW, the balance being shared by reducing the charge rate with home loads automatically.
Maybe there is another set-up up that anyone can suggest?
I keep a look out for a larger style 2nd hand 20kw gen, though never see them come up for sale.
THanks!
THanks!
