Question on EVE LF280K dimension
burgerking
Subic, Philippines
According to EVE data sheet, they produce their LF280K batteries with posts/terminals spaced at 123mm apart.
Technically, when placed side by side on the short end, the terminal will be about 50mm from the other cell.
Yet I am seeing people have their EVE LF280K's terminal spaced ~80mm apart from the next cell.
Is it just a factory deviation, wherein one was made from Factory X, while the other was from Factory Y?
Just slightly pissed, I bought a few busbars for 80mm holes, and got cells that needed 49mm holes.
Where are you seeing people have K's that are 80mm apart? The N's aren't even being made anymore so if someone has 80mm apart ones they are old N's. The K's are also couple mm taller.
