FloridaSolarMan
- Sep 11, 2021
- 8
Hello,
I am currently trying to pick my inverter setup which needs to be 240V split phase and at least 4000w. My battery is 24V.
I am considering both individual components as well as all-in-ones. From my shopping around it looks like my options for all-in-one setups are limited to those which can be setup in parallel which narrows it down to basically 2x MPP Solar LV2424 or 2x Growatt 3000 (not sure the model #).
What I am wondering is on the parallels if I always need to power both on for my system to be operational or if there is a way I can setup or wire these inverters such that I can run a load with just one inverter powered on, and only have both on when I need the 240V split phase output (for my well pump).
Esp when running off the battery with no solar coming in, it's a waste to have both units running to power a load which a single one can easily handle. If my thinking is off here, please let me know.
If such is the case then I may opt for stand alone components (looking at Sungold 4000W Split phase or Schneider Conext 4024).
Appreciate the help!
