Question regarding ecoflow delta pro and panels recomendation
outshined
Hi,
Ordered an EcoFlow Delta Pro from Costco and am looking for panel recommendations.
I currently have two of the EcoFlow 160w panels. (from a previous Delta unit my Daughter will inherit)
I have $1000 to spend on more panels.
Recommend me products to help keep this thing charged.
Edit: upped my budget to spend on panels.
I found these:
GS-Star-100w https://grapesolar.com/wp-content/uploads/GS-STAR-100W.pdf on sale for $90
and these:
https://www.harborfreight.com/100-watt-monocrystalline-solar-panel-57325.html for $120
I noticed the grape solar was listed as 12v and the thunderbolt ones as 24v. Does this make a difference in time it actually takes to charge the Delta Pro? Are the harborfreight pannels worth the extra $30. They do have kickstands but also have an SAE plug that I assume I will need to replace.
Ecoflow has a 400w pannel listed on their website that is currently unavailable.
I am new to this and have relied on the EcoFlow panels I mentioned in my previous post and really need help trying to find the products and configuration that is best suited to my budget to work with the delta pro.
Thanks
Did you ever find a good solution for your EcoFlow? I'm in a similar situation for a purchase. Here's my thread if you're interested.
Hi,
“Shop Solar Kits” has pre-configured kits that match the Ecoflow batteries with appropriate solar panels. If you just need the panels, then you can order them individually. https://shopsolarkits.com. If the opportunity presents itself, and items are in stock, you can never go wrong by ordering the panels from Ecoflow.
