Oregon Farm
Hi all, new to the forum but long time lurker. I have learned a lot from the great minds here so thank you!
So I am upgrading my EG4 6000EX and installing two EG4 6000XP. I thought it would pretty much be plug and play but the solar input has me scratching my head a little.
I currently have two strings of 250 watt panels, each string is 9 panels wired to one single 10 gauge solar input wire for my 6000EX (solar disconnect and fuse in line of course). The two strings are wired in series (9 panels per series) and then they are wired together in parallel. My maximum Voc at 14°F is 371.3V. The Impp (amperage) of each string is 8.35 A so with them being in parallel that gets me to 16.7 A.
What I didn't realize is the 6000XP appears to have the two mppt charge controllers with a max system voltage of 480 V and max system amperage of 25 A. So as I read the owners manual this is cut in half per mppt correct?
The 6000EX only had on mppt and could take this all in one wire run (which is buried in conduit underground).
So, do I need to split my existing single +positive and -negative wires off into two connections to get my max amperage per mppt down on my line? What is the best way to go about this? I am assuming the best way is a standard PV splitter connection and just don't use MC4 connections going into the inverter.
Thanks in advance!
Thanks in advance!
