Homesteader Jon
HI all. I'm new here.
Background:
I am putting in an EG4 FB21 + GB + 2 x EG4 All Weather 14.3kwh EG4 Wallmount Batteries, next week.
(Also PV: 6kw of panels across 2 x 2-axis tracking towers plus some ground mounts to get me started. I may expand PV next year. BTW, Aptos 460W Bifacial Solar Panels)
I purchased an RSD switch for outside my home, to place by the meter, for first-responder safety.
Question:
I was going to purchase manual PV disconnects for the two planned PV arrays. One for the 2 towers, and one for the ground mount array, since they are on separate PV wire sets, going back to the FB21 inverter.
I see that this inverter is capable to controlling PV RSDs for the through Tigo receivers, which seems to be a built-in capability of the FB21.
Now I'm left wondering, if I buy a couple of these Tigo remote RSD boxes for the arrays, do I still need (or would it be recommended to), still add manual PV disconnect switches out at the arrays as well, or am I over-engineering it?
Perhaps I can I just command the Tigo PV RSDs to shut off the arrays, to work on them, without activating the RSD for the entire system?
I know, I know, RTM, but I'm trying to get a quick answer, so I can get my remaining parts on order today and I will study that part of the software manual later to see if there is an option to just remote disconnect the PV only, using the Tigo boxes, without have to do an RSD of the whole system.
So would you recommend just the PV RSDs or just the manual PV disconnect switches, or both?
TIA, Jon
Background:
Question:
TIA, Jon
